Just bought a '17 Q5 3.0 and wanted, as I usually do, to get a top or best oil. I'm using Castrol LL03 for my TDI so I decided to do a little research on what Castrol offers. I called Castrol, their female reps that answer the phone seem to also be their tech line...wonderful. According to them the OE oils are the highest level of protection and are 100% carbon neutral (?) and filtered better, "Exclusively for new car dealerships, Castrol EDGE Professional is certified carbon neutral and micro-filtered to highest quality standards." When they emailed me the data sheets the info on them as compared to the regular EDGE of the same weight look exactly the same. My dealer says that the black bottle EDGE is the same oil (they do not carry the OE) and got an attitude when I told him that Castrol says different. Still trying to find out which is the best oil, I usually buy a few cases and a bunch of filters and whenever I want the car to rum smoother, I change the oil.....Is it worth getting the OE, or maybe an even better oil?
This is the info from the data sheets:
**EDGE Professional OE 5W-40** GOLD BOTTLE
Strength for Maximum Performance
Description
Today's technology has allowed car manufacturers to produce smaller, yet more powerful and efficient engines with the
aim to deliver increased fuel economy, reduced emissions and high performance. Downsizing, turbo charging and
advanced engine designs like direct fuel injection and variable valve timing have now almost doubled engine pressures
putting more stress on the oil. The oil is now operating under higher temperatures and having to withstand pressures in
excess of 10 tons of pressure per square centimeter in areas like the cam and follower.
Application
Formulation approved and licensed to European OEM specifications.
Meets the industry standards for API SN/CF and ACEA A3/B4.
See product performance claims for a complete list of OEM approvals.
Advantages
quality standards.
Typical Characteristics
Name Method Units Typical values
Density @ 15C, Relative ASTM D4052 g/ml 0.85
Appearance Visual - clear and bright
Viscosity, Kinematic 100C ASTM D445 mm²/s 14.1
Viscosity, CCS -30C ASTM D5293 mPa.s (cP) 6100
Blend Flash PMCC ASTM D93 °C 210
Viscosity, MRV / Yield Stress -35C (5W) ASTM D4684 mPa.s (cP) 36000
Viscosity Index ASTM D2270 None 174
Viscosity, Kinematic 40C ASTM D445 mm²/s 84.2
Viscosity, HTHS 150C ASTM D4683 cP 3.7
Noack Volatility CEC L-40-A-93 % Loss 11
Pour Point ASTM D97 °C -45
Product Performance Claims
ACEA A3/B4
API SN/CF
BMW Longlife-01
MB-Approval 229.3
Porsche A40
VW 502 00 / 505 00
**EDGE 5W-40 U.S.** BLACK BOTTLE
Description
Advances in engine technology have led to increased power and efficiency, meaning engines work harder and under
higher pressures than ever before. The only thing keeping engine components apart is the oil, so it needs to be strong
and remain strong. Castrol EDGE is our strongest and most advanced range of full synthetic motor oils. It provides
superior motor oil strength and help your vehicle to maximize performance.
Application
Formulated for approved and licensed European OEM specifications. Meets industry standards for API SN/CF and ACEA
A3/B4. Meets BMW, MB, Porsche and VW specifications.
Advantages
Castrol EDGE provides superior motor oil strength for engines that work harder due to higher engine pressures,
helping your vehicle maximize engine performance.
* Reduces metal to metal contact across a range of different driving speeds.
* Protects the engine for the entire drain interval as recommended by your owner's manual even under extreme
pressure.
* Decrease engine deposit formulation to help maximize engine performance
Name Method Units Typical Values
ACEA A3/B4
API SN/CF
BMW Longlife-01
MB-Approval 229.3
Porsche A40
VW 501 01/ 502 00 / 505 00
Old thread from VWVortex, not sure if info is still valid...
https://forums.vwvortex.com/showthread.php?8693017-Passat-VR6-owners
