Hello, I have a 2006 Audi A3 with a 186,000 miles. I have due for an oil change and want to know the best 5w-40 (VW 505 01) oil from the below by comparing their data sheets:
1. Motul X-Clean 5w-40
PROPERTIES
Viscosity grade SAE J 300 5W-40
Density at 20°C (68°F) ASTM D1298 0.845
Viscosity at 40°C (104°F) ASTM D445 84.7 mm²/s
Viscosity at 100°C (212°F) ASTM D445 14.1 mm²/s
Viscosity HTHS at 150°C (302°F) ASTM D4741 3.6 mPa.s
Viscosity index ASTM D2270 172
Pour point ASTM D97 -39°C / -38.2°F
Flash point ASTM D92 234°C / 453.2°F
Sulfated ash ASTM D874 0.80% weight
TBN ASTM D2896 7.5 mg KOH/g
2. Castrol Edge FST 5w40
Density @ 15C, Relative ASTM D4052 g/ml 0.85
Viscosity, Kinematic 100C ASTM D445 mm²/s 13
Viscosity, CCS -30C (5W) ASTM D5293 mPa.s (cP) 5800
Viscosity, Kinematic 40C ASTM D445 mm²/s 75
Viscosity Index ASTM D2270 None 174
Pour Point ASTM D97 °C -42
Flash Point, PMCC ASTM D93 °C 202
Ash, Sulphated ASTM D874 % wt 0.8
3. Millers NANODRIVE EE LongLife 5w-40
SAE Viscosity 5w40
Specific Gravity (at 15°C) 0.848
Kinematic Viscosity (at 100°C, cSt) 14.1
Kinematic Viscosity (at 40°C, cSt) 85.9
Viscosity Index 170
Pour Point (°C) <-36
Flash Point (°C) >200
Cold Crank Viscosity (cP) 6,600
4. Red Line High Performance 5w40:
API Service Class: SM/SL/SG SM/SL/SG SM/SL/SG SM/SL/SG SM/SL/SG SM/SG/CF SM/SL/SG SM/SL/SG SM/SG/CF SM/SL/SG SM/SL/SG
CF CF CF CF CF CJ-4/CI-4 CF CF CJ-4/CI-4 CF CF
Viscosity Grade:
Vis @ 100°C, cSt 15.1
Vis @ 40°C, cSt 94
Viscosity Index 170
CCS Viscosity, Poise, @°C
[email protected]
HTHS Vis, cP @150°C 4.6
ASTM D4741
Pour Point, °C -45
Pour Point, °F -49
Flash Point, °C 250
Flash Point, °F 480
NOACK Evaporation Loss,
1hr @ 482°F (250°C), % 6
The Red Line oil is significantly more expensive than the others but will it be worth it? I change my oil once a year (every 12 months) and do circa 5k miles a year (70% city and 30% motorway). Note, I live in the UK.
