Originally Posted By: wirelessF
Originally Posted By: Jason Adcock
Hmm I see they removed the battery and oil pressure gauges. Is it those "base" instrument clusters where they only give you MPH, fuel level and temp gauges?
I like the semi-real oil pressure gauge on my Tundra. Semi-real as in the needle moves varies on RPM but does not give an actual reading.
Wireless, you need a reality check. No mainstream sedan has offered an oil pressure or voltage gauge in decades. You won't find these in an Accord, Altima, Impala, Malibu, Taurus, Fusion, etc. either. And did you overlook that nice, big, tach?
And you're incorrect about the Tundra's OP gauge too. Certain makes (most notably Ford in the Explorer and pickup) have been "acknowledged" for their fake OP gauges that only mimic the behavior of a warning light (up or down, on or off). We had a Sequoia for six years, same gauge, and it reflected the actual oil pressure across a wide range of conditions. Yes, OP will often track with rpm, no surprise there, and that doesn't make it a fake gauge.
