John Deere Oil Filter Pics
Ohio
This is from my mom and dads JD 345 18HP Liquid cooled Kawasaki. The filter has 112hrs on it, I guess my dad changed the oil at about 50hr intervals but left the same filter on for 112 hrs.
This is the same filter I run on my JD 20hp liquid cooled Kawasaki. Looks pretty good.
Don't know if you have the inclination or the room, but you could run a Puro 14477. It's the same filter, just longer. I used them for hundreds of thousands of miles.
I cut open the John Deere OEM version of that filter. The filter element was about an inch tall.
I showed it to the John Deere dealer, and never bought another one.
I now use the Puro Classic pictured above.
Originally Posted By: Stelth
Nice. How's the adbv feel?
It was very pliable, not hardened at all.
Don't have the room.
I found you can run the Kohler filters on some of the Kawasaki engines used in JD...the sealing surface boss on my 19HP Kawasaki in a JD Gator fits both filters. That might give you more choices in length?
I also cut the OE JD filter open...the element was really small as mrsilv04 indicated, but (other than adding volume) does it matter?
I just cut open a JD AM107423 and the element was about 2 inches tall. But, the paper on the Puralator looks much better regarding number and evenness of pleats. Looks like a winner.
funny thing, most jd filters are champ made, i know the kaw am107423 is for sure, and its no higher quality than a super tech
