John Deere LVA16054 by Donaldson, Hydraulic Filter, 1025R, 57.1 Hours
Folks, here is the OE hydro/hydraulic filter off of my 57.1hr 2022 John Deere 1025R. This filter is either unlabeled due to being OE or just covered in black paint... I think the later is the case as it's probably installed then the entire hydro unit is painted. The replacement LVA16054 has Donaldson logos on it, so I am to believe thats the manufacturer.
Few weeks back when purchasing this filter, the local JD Dealer Service Manager was kinda weird with me for wanting to change the filter and Low-Vis Hygard fill on the tractor with only 50hrs. Said don't do it until 200hrs. I am pleased I followed my intuition as this filter was grey with material and the suction tube + magnet both needed cleaning. I am thinking the 50 hour break in change for the hydro/hydraulic system is not a bad thing, plus they used to preach the 50hr service interval. Me thinks its a "lower TCO" bragging point.
Filter seems well built, nice baseplate, pleats look decent -- maybe a little wavy but not a big concern as the media is wire-backed and seems to be a synthetic media. Not like I have much of a choice anyways as I have never found a cross-reference and Donaldson never replied to me!
Anyrate, enjoy!
Thanks for the cut and post. Looks well made! Dealer service departments for equipment usually know next to nothing about oil and filters. They often just repeat whatever the books say for intervals, and sell whatever bulk oil and filters they can get. Occasionally you will find some who really know their stuff, but those are less common these days.
Use case and storage time/location are important factors, not just hours. 100 hours of mowing/loader work within a few weeks time is a lot different than 100 hours of use over 4 or 5 years on a machine stored outside for example.
there mis lots on stuff in Hydraulic systems that is why there is the pre filter screed. Shared transmission and hydraulic oil is the smaller tractors.
Wow, you don't really expect a lot of debris in hydraulic systems but there was plenty of metal? is it magnetic? Good pics.
Thanks, I will check tomorrow. My thoughts is this is the initial break in. Maybe it trends better as time goes on?
Anyrate, enjoy!
Nice filter. Thank You for great photos and cut and post sir 👍🇺🇸
It should. Hydraulic systems are kinda like engines. They have a break in to them. Usually not as much as an engine because of the highly precision manufactured parts but you will still get some debris shedding.
Just my $0.02
The link reflects a quick operation and maintenance guide for Yanmar SA series tractors. I know the engine on a SA324/325 and 424/425 is fundamentally the same as in the 1025R JD. I am not sure about the HST tranny. However, Yanmar specifies HST fluid replacement at 50 hours and every 300 hours thereafter. I just crossed 26 hours on our 23 SA425 yesterday and have parts ready for the 50 hour service. Will change the engine oil in the next week and then again during the 50 hour service. Will follow recommended service thereafter other than yearly or sooner engine oil changes.
Update, I still haven't check to see if its magnetic.
But I did mow today and ran the tractor a bit. The hydro is a lot quieter with the new filter, fluid and cleaned suction tube screen. Starting to think the early service is nothing but good.
That’s pretty common with the 1 series tractors. They all have a lot of metal in the screen on the first couple changes. That one sump is responsible for the transmission, differential and all of the hydraulic system(drive, steering, 3 point, loader, backhoe if equipped). There’s usually some excess silicone stuck to the screen or in the bottom of the housing too.
Deere should’ve never stopped the initial 50 hour service on the hydraulics. This post and the posts all over the green forums and social media pages proves that. The faster that debris is removed the better. My 1025r was the same way along with the one I ran for a school district when I did grounds maintenance.
Ah, I didn't know that & was thinking along the lines it was just for the lift/PTO system. Yeah that is a lot to ask of a fluid to run for that long in the beginning. Thanks for the details.
I believe the OE fuel and oil filters are unlabeled black. They were for the 2022 JD 318G and the 2024 325 skid steers out here. The JD replacements, if I recall, are white and do have minimal markings.
On Volvo CE we dont even change the hydraulic filters before 2k hours. If it uses Bio oil we dont even change the oil at all. just do a UOA. Also a huge amount on the magnetic stick for 57h. Dont even see that much on 10k hour machines.
