quote:
From what I've read it seems that Leichtlauföl refers to Hydrocracked oils whereas "vollsynthetisch" are the true synthetics. The possibility does remain that under an overall category "Leichtlauföl" are the vollsynthetisch (whole synthetic), the teilsynthetisch (part synthetic or synthetic blends) and the HCs or hydrocracked
pscholte,
The term "Leichtlauföl" refers to oil with friction modifiers, but almost all of them were full synthetic oils. I know that German full synthetci oils are usually labeled as "Vollsynthese" oder "vollsynthetisches Leichtlauföl."
I guess every full sythetic oil is also a "Leichtlauföl," but not every "Leichtlauföl" is necessesarily a full synthtic oil. It could also be an "HC" oil. And that's also a label I see on oil sold in Europe.
The issue came never up when I owned a car in Germany (late '80s/early'90s). I put a full synthtic oil (BP Strato) which back then cost already $15 per liter, and I never used any HC or dino in my '89 Scirocco. I just went with the dealer's recommendation, which was that particular oil.
quote:
According to EU Audi manuals, column A oils are 500.00 spec oils, and column B oils are 501.01 spec oils. For some reason, these labels were removed from US manuals (although EU manuals say if mineral SF/SG is used follow the 501.01 chart). 500 oils are typically synthetic and synthetic blends, and 501.01 are dino and very heavy synthetic and synthetic blends. Not all synthetic oils pass 500.00 specs and not all dino oils pass 501.01 specs.
M1 xW-30 did not pass 500.00 (or the newer 502)because of HTHS and other VW/Audi seal/wear/sludge requirements. I believe the EU Castrol 0W-30 is 502/500 spec. So, not all synthetic xW-30 (and xW-40) oils meet 500/502.
Yes, you are reading the chart correctly, but I'm not sure if the VW500.00 oils were usually not true synthtics. It really doesn't matter anymore, because VW500.00 has been superseeded by VW502.00. That's the spec I'm looking for when chosing an oil for my Audi, despite the fact that there was no VW502.00 when my car was made. VW501.00 has been replaced since, too.
I find it interesting, and disconcerting, that M1 0W-30 does not meet VW502.00, because so many fellow Audi drivers actually use it! Audi seems to have a double standard regarding oil recommendations: "Here, if in Europe use only this good stuff that meets those very particular VW specs, if you are outside of Europe, then just put anything in."
And I think this might hint at what's going on with some makes now. Some car manufacturers seem to strictly endorse certain products (underhood sticker). Maybe it's to ensure peole use the correct oil? Let's face it, who, apart from people like us, compares oil spec sheets?
PS: quadrun1, your friend's car has the 30 valve engine, mine's still a 12v. It may well be that Audi does not recommend any oil heavier than 5W-40 for that engine.
