Is this an offset woodruff key?
My 2008 propane Dixie won't start. It's getting spark, compression, and I smell fuel. I pulled flywheel to check key and can't tell if it is designed this way or if it's getting ready to shear. Engine is a GTV760 and according to parts manual it takes part number 082774 (4x19d) which is pictured as an ordinary half moon key with no offset.
Welcome to BITOG.
That does look like an offset key to me but I don't think they used those....so, not sure to be honest. Hopefully someone will chime in with more experience.
You can often get a set of replacements at Harbor Freight Tools. Cut and file to size.
That key doesnt look damaged, it looks like an offset. The manufacturer of the unit may specify different timing, do a deeper dive into this before replacing the key with a straight one.
Well if that keyway got machined in the wrong location on the crank and you have hundreds if not thousands of bad cranks you have to come up with a creative solution for a cheap fix to save all those bad crankshafts. Hence the offset key. I've seen a few things done with bad parts over the years. That crank key look like it was made that way to me perhaps for a reason and not damaged.
What is the actual model number of the engine? Jack's small engines lists 4 different GTV760's that call for the 082774, and a 5th GTV760 "OLD" (as they list it) that calls for a 062774 woodruff key that's NLA. Perhaps yours, being an '08, is the "old" version of the engine that takes the alternate part?
The discontinued 062774 Woodruff key crosses over to a G082774 Woodruff key which is not offset.
That little bit of advance shouldn't be the cause of not starting. Propane has a high octane rating but lower BTU content so the timing is likely advanced a bit to help reduce the power loss from the gaseous fuel. Maybe shut off the propane supply, and try starting it with a small gasoline prime.
I can't thank everyone enough for helping me keep this mower running. As far as any numbers on engine, I can find none. The original tag had nothing but engine size. There's no model/type numbers anywhere like on other engine manufactures. I've attached pics of key and just from looking, it seems to me that it's made with an offset. I did try to drizzle small amount of two cycle mix in one of the cylinders and didn't even get a pop even though it does have spark and compression. I reached out to Generac hoping to get some info with no response.
