I have a co-worker's mower for repair. It's the newer "value" or E line of OHV Briggs engines that replaced the old flat head "Classic" line. No start. It has fuel in the tank. Primer gets no fuel to the carburetor. Okay, got it. It should at least cough on starting fluid...that would confirm ignition. No cough at all. Pull plug and cord...the plug does spark (strong). Hmm. Check flywheel key...that's good. Check valve lash...that's good. The engine feels like it has compression. It doesn't feel super tight like an older Lawn-Boy 2-cycle, but it feels decent. Governor arm seems to work right...throttle is wide open at rest (as it should be). There is no choke...just a primer bulb.
So. It has air. It has spark. It has fuel (aerosol carb cleaner). It should be timed correctly (good flywheel key). It feels like it has compression. I'm not sure if the head is removable on these newer engines or if they're a "uniblock" like the Honda GCVs. I'm thinking that it's got to be a mechanical issue in the engine. But even if it were missing a ring or two or even had a hole in the piston, you'd think the carb cleaner would at least "pop" with the spark, right?
