Greetings:
My neighbor has a five year old Craftsman snowblower with an 8.5 HP Briggs and Stratton OHV engine. It is a constant speed engine (no throttle control.) It has low hours on it and now doesn't want to run. It has spark and the non-adjustable plastic carburetor was taken off and cleaned to no avail. The spark plug is new and the engine seems to have plenty of compression.
If you push the primer a few times and give it full choke, it will start to fire. Pumping the primer will barely keep it running. If you start to open the choke it stalls.
My neighbor thinks he should just get a new carburetor. I looked at the carburetor myself and it seems to be really clean internally and the float/needle look like new. I tried squirting carburetor cleaner through all of the orfices/openings that I could see and this did not help. He told me that he actually had it off and ran a piece of very thin, soft wire through the openings and did not find anything clogged. He mentioned the possibility of a sheared flywheel key, but I would think that it would not start at all if this were the case. Any thoughts on what could be keeping this engine from running?
Thanks!
Andrew S.
Thanks!
Andrew S.
