amsoil vs frantz? Any info or links out there which is best and why?
Best in what way?amsoil vs frantz? Any info or links out there which is best and why?
Ok true to that I’m just guessing the all perform about the same. And the data is in the oil analysis. So running something is better then nothing. I’m already running a amsoil bypass 110 I was just wondering if I should be using something else.Just about any typical brand name BP system will do a fine job at reducing particulate load over long OCIs.
I don't know of any true, unbiased study that would idicate one better than another. Especially when "better" is a very subjective term.
Not really. What kind of analysis are you running?Ok true to that I’m just guessing the all perform about the same. And the data is in the oil analysis. So running something is better then nothing. I’m already running a amsoil bypass 110 I was just wondering if I should be using something else.
Yes it can. I’ve just rarely if ever seen people post such an analysis here, and with history for comparison.A PC (particle count) oil analysis will show the reduction of particulate in the oil; that would be beneficial.
I've studied BP effects in use, and compared/contrasted those to marketing claims, and come to the conclusion that ALL of the decent brands (Amsoil, Frantz, FS2500, etc) do a very good job of reducing particulate matter above 3um in size with excellent efficiency, and that is of a size that is essentially harmless to an engine. So essentially, the "performance" of the BP filter is assured. Therefore you should use other criteria to make a product selection. Initial cost of system, maintenance cost of elements, size/fit for your application, ease of getting replacement elements, etc. Take into account all these and then weigh them to your own personal needs.
It doesn't come apart at all. I have a TP bypass filter (Motorguard) in the coolant system on my truck, and it just works.
I think that we tend not to see any before/after comparisons regarding the effectiveness of bypass filters because very few run a baseline analysis on their oil. I know I didn't start taking samples for analysis until after I'd got by oil bypass filter installed.
I second what Mike says. I run these on every vehicle I own and have never had an issue with the media breaking apart. On my F350 I run 3, engine lube, transmission, and fuel.the only thing that is questionable about Frantz is that it looks like TP, I'm always worried about the filter media breaking apart and clogging oil galleries. I'm probably wrong but just a theory I have in my head.
How is that Beast running?I second what Mike says. I run these on every vehicle I own and have never had an issue with the media breaking apart. On my F350 I run 3, engine lube, transmission, and fuel.
It's running really nice thanks, couldn't be happier with it.How is that Beast running?
It was quite the project to get it where it is .It's running really nice thanks, couldn't be happier with it.
Starting a new one this Spring. 1947 Diamond T on a Ford F550 Chassis and powered by a Detroit 4-53T Silver.It was quite the project to get it where it is .
Is the Silver line similar to the 8V 92 Silver series? While I detest the 2 stroke Detroits, [having them in freight trucks] The 8V 92 in the [I think ] 365 and 430 hp were wonderful to drive. Post pictures !!!!Starting a new one this Spring. 1947 Diamond T on a Ford F550 Chassis and powered by a Detroit 4-53T Silver.
Yes, the 4-53T Silver Series was introduced in the mid to late 80's. They took what they learned from the 92 and 71 series and modified the 4-53T. I run one daily in my F350 and a really nice engine.Is the Silver line similar to the 8V 92 Silver series? While I detest the 2 stroke Detroits, [having them in freight trucks] The 8V 92 in the [I think ] 365 and 430 hp were wonderful to drive. Post pictures !!!!
Back in the late 70's, when I was living in the dorms at college, we bought several Frantz filters. They DO look like toilet paper rolls, but they can't be unwound.the only thing that is questionable about Frantz is that it looks like TP, I'm always worried about the filter media breaking apart and clogging oil galleries. I'm probably wrong but just a theory I have in my head.
