Just curious if a bypass filter would help this car. Its a 2008 BMW 750LI 4.8 LTR. It runs very hot and has a known issue of the valve seals drying and becoming hard , this allows the oil into the combustion chambers. To repair this problem can cost in the thousands so I am hoping to find a solution. Some have suggested running a lower temp thermostat ,that will make the motor run cooler but I've been told you sacrifice fuel millage which is something id rather avoid. I am seriously looking at a bypass filter as a means of 1) allowing the oil to be cooler. 2) the oil will be cleaner so the engine being an aluminum block will hopefully get more miles due to the cleaning effects of a bypass filter. 3) since a bypass adds an additional liter of oil , it would benefit the engine oil running cooler but would help not to cook the valve seals. 4) running the oil longer between changes. if this is all true what would be the best Bypass filtration system ?
