How does a bypass (finest filtration bypass, for this question) filter affect oil analysis?
I don't mean to ask if the engine wear will be less, I mean to ask will the bypass filter filter out very fine particles, water, antifreeze, or any other substance that is actually happening in a vehicle which would otherwise be caught in oil analysis?
Or to put it another way:
If I run my '93 Dodge diesel for 5K miles, get the oil all nice and black and contaminated. Then....
One sample of the oil, as is is bottled for testing.
Then...
The rest of the oil is run a few times through the best and finest bypass filter (TP?) setup. A second sample is then taken of the "super filtered" oil and sent in.
What are the possibilities for different test results?
If I was having high iron or bearing wear, or antifreeze in the oil, could a very efficient bypass filter cover up this problem?
Thoughtful responses will be very much appreciated.
(the great thing about BITOG is the high number of quality responses!)
Thanks
Then...
Thanks
