Originally Posted By: Thermo1223
We get it you got bit bad...you are ONE person!
Toyota's Hybrid system is not without it's faults especially regarding inverter failures.
Everyone can get a lemon... you did, it happens, move on with life. So you'll never buy another VW, doesn't mean the whole of the world won't.
I'm not alone in my VW experience. I despise subjective "information". I'd much rather have "the facts". Here is a direct comparison between the year Jetta I owned and the Prius. The trend continues to this day, with the newer models. This cannot be denied.
Here are some owner comments from various owners:
Jetta: Complete failure of fuel system and high pressure fuel pump sent debris throughout. $10,000 repair cost covered by warranty.
Jetta: High pressure fuel pump failure. Fuel injectors, tank, rail, pump, and all lines needed replacement.
Jetta: The Clutch started to slip and needed replacing. I've read online about the pressure plates on manual transmissions having issues; guess this is correct.
Jetta: Intermittent rough idle. Batch of cars with bad injector pumps. VW replaced some under warranty, trying to stiff a lot of others with cost of replacing whole fuel system, about $9k. A number bought back, but owners must agree not to post about it.
Prius: Bluetooth connectivity to telephone would not work. The Bluetooth antenna was replaced.
Prius: Front brake pads make a metallic rattle sound when going over small sharp bumps, like Botts' dots.
Prius: brakes making a ticking noise. they haven't been able to resolve it
![jqef.png](http://img35.imageshack.us/img35/5964/jqef.png)
