Your assumption is that there is nothing beyond those specs. We don't know exactly what specs BMW considers/tests when approving an oil for use in their engines. Do we?
What exactly about your 3.0 requires synthetic oil?
Dual vanos? I have no idea. I didn't design this engine, and neither did you. The fact that we don't know doesn't automatically make it OK to disregard the mfg recommendation.
I'm not "disregarding mfg instructions", I'm updating and improving them. Just like I did when Audi started specing 10k intervals in the 1.8t with a tiny filter the year I got a new one in 2002. Should we (have) "disregrded" the mfgs recommendation then? Well it turned out the mfg was ~wrong~. I guess the 15k BMW changes are observed strictly by you all?
I feel like this thread is in some virtual bizarro-bitog. Since "we" don't know all the requirements for LL-01 (an old spec by any accounts) why not speculate on them, like is the norm here.
mpg
ht/hs
cold-cranking
volitility
deposit control
wear
shear
tbn (sludge control)
extended drain capable (anti-oxy/nitrate)
My informed guess is that a conventional 10w40 like GTX would meet all but one or two of these criteria, mpg, cold-cranking, true extended drain. Seeing as how the spec it does carry, API SM, has a set of rigourous tests and published specs, which exactly equaling the physical characteristics of the published specs of the BMW oil!
Hmm.
The HD oils have a mind-boggling array of oem approvals, Delo carrying A3 at one point, yeah, the Euro spec.
Taking the example of Euro GTX 10w-40 "Mineral" having ACEA A3 their spec requirements, all of which exactly mirror the BMW specs.
There is just no disputing the API and ACEA specs, is that why you're not trying? Comparing them to BMWs is just a matter of doing a little homework, which I did short of pulling the API specs for deposit control, etc.What I found was a vast array of examples of oils that cover the specs as we know them, I mean as *I* know them.Can *we* get a copy of the BMW specs without me having to do all the work?
