At this point a set of gauges would be helpful; pressure readings should point you in the right direction instead of just guessing.
A poorly performing condenser would manifest as a high reading on the high pressure side.
There's tons of info online how to interpret gauge readings,
this is one example.
I had a mechanic botch an AC job not too long ago (overfilled system), that was all it took for me to pony up the money on the tools to do it myself. Buying a vacuum pump and set of gauges was some of the best money I've ever spent, both can be had for under $200 at Harbor Freight. Saves having to rent one every time you need it, and I just don't trust a rented vacuum pump. I called around and found a place that would evacuate refrigerant for $20 as long as I called ahead of time and they weren't busy. I won't give you too much grief for exhausting it into the air as I'm sure many of us have done it in a pickle, but you should be able to find someone that will do it inexpensively.
