Is my AC cold enough?
I was sweating when it went up to 55 degrees at the vent. It's about 82 in the cabin, 95 outside.
55 at the vent is not good, I can see why you'd be sweating. I went through that last summer with my 88 E-150. I had two leaks, one at the high side Schrader valve and the other at an O-ring in a line in front of the condenser. I addressed both issues, replaced the receiver drier, pulled vacuum and weighed the charge. It is blowing nice and cold now.
You are supposed to weigh the amount of refrigerant being charged. Most likely why it is not working properly.
Yes I suppose I'll start over and charge it myself. My mechanic said it wasn't very cold when he serviced it but he didn't know why. I don't know exactly what he did but he may not have done it right
One more thing. Should I add some oil or not? That's the only thing I get mixed opinions on. I know how to do everything else.
My refrigerant capacity range is 14.4 oz minimum to 16.64 oz maximum. Should I put in just under the maximum amount?
When you park it, leave the windows cracked a bit to reduce the heat build-up that the A/C then has to overcome. Obviously, don't leave anything of value in the car, but I wouldn't imagine a 12yr.-old Vibe is a big theft target itself.
