Is it time to just say no?
Originally Posted By: Trajan
Originally Posted By: Trav
Someone was using the man's name to post stuff on the internet a while back.
Its not right and i want nothing to do with kind of nonsense. Keep it real and keep it honest or don't post it.
+1 Someone used my name to post garbage too, that isn't right!
And not just your name. Gary Allan, Gary Allan Jr, dnewton3 are just a few. His account got suspended at f150online, and no one at E46fanatics bought into his nonsense either.
You're right!
You're right!
For example: http://www.f150online.com/forums/v8-engines/470135-just-finished-my-first-1000-miles-autorx-2.html
Claims to be GA's son. And *happens* to find the obit in a *lucky* search. There's a few dead giveaways too.
And word for freaking word, the same here: http://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2628283 under dnewton3.
Interesting to find this in that thread:
I'm about 600 miles away from completing the first rinse cycle of a 2 clean rinse phase application. The 164,000 mile Vulcan Aerostar seems to be running well, oil use is up slightly. I'm anxious to hear about your consumption. At this point I can now say I feel a slight increase in power, but as you say its a moot point. The wife says the Aerostar runs great so I'd consider that a plus
Frank D
Originally Posted By: antiqueshell
Funny how not ONCE in this thread has ANYONE brought up the issue of WHY such snake oils refuse to pay for
INDEPENDENT, CERTIFIED TESTING, FROM A WELL KNOWN ORGANIZATION (eg SAE).
When MMO, or any of the other snake oils can bring me scientific proof of improvement, then I will be interested in their claims.
It's been brought up before. Just gets shouted down.
One thing that has been proved here today is how honest Trav is and how we can trust him. He immediately alerted everybody that the reply by V8man might be inaccurate. And demarpaint has also been misquoted and his name used by some mysterious individual who uses the names of various people and posts under their names, at least in some other website forums.
Trav and demarpaint are two of the people here I trust the most and you can see why. Very good job Trav.
Frank D
That was early on for me and A-Rx, nice find, old news people who know me know I was a fan of the product. Did you read what I wrote about the leak it stopped and how it came back? Keep digging you'll see how Trajan and Gary Allen used and liked MMO. Things change all the time. I stopped using Mobil 1 a few years back, I have a stash with over 60 qts of it now.
Frank D
60qts??? Dang!! Why not use it up. And yep, things change. I used to use MMO in gas. Now TC-W3 as it's even cheaper
Originally Posted By: V8man
ARX - why it IS the miracle fluid!
dnewton3
Loc: Indianapolis, IN
I just completed my second ARX application/rinse. I don't know that there are enough superlatives I can find to express how pleased I am with the performance of ARX.
For those who don't know my story, read the whole thing here:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1128803&fpart=1
But if you want a synopsis, I'll provide this:
1997 Taurus 3.0 Vulcan; heavily coked piston rings. Very poor compression. There were two treatments of ARX application/rinse. First was an "experiment" with Frank and Gary; second was a "traditional" treatment. The initial test was 2x the dose for 1k miles, followed by a 2k mile rinse. The second application was at 90k miles with 2.5k miles application and 2.5k miles rinse.
The final result?????
ALL CYLINDERS ARE NOW AT FULL COMPRESSION! The last lagging cylinder (#5) is now up over 180psi in yesterday's compression test, along with all the rest. The following is a recap of the compression in psi, with each reading taken at the beginning of the event.
event.....2app..rns...1app..rns.....final check
milage....87k...88k...90K...92.5k...95k
cyl 1:.....170...180...180...180.....180
cyl 2:.....170...180...180...180.....180
cyl 3:.....165...180...180...180.....180
cyl 4:.....120...180...180...180.....180
cyl 5:.....110...150...160...170.....180
cyl 6:.....180...180...180...180.....180
Lets take a look at these compression numbers with Pennzoil Platinum and auto-rx, followed by the numbers with auto-rx and conventional oil. At 85K Pennzoil Platinum 5w30 was put in this engine, at 87K compression numbers were taken and auto-rx was added in the oil.
At 88K compression numbers were taken again, cylinder #4 went from 120 to 180, so that cylinder is fine. We now have cylinder #5 going from 110 to 150, the problem is that we do not have compression numbers when this engine had 85K. This engine had a mishap at 50K when a freeze plug bursted, right near cylinders 4 and 5. What is interesting is that there were no problems from 50K onward, meaning there was no sign that there was a compression problem, the engine ran fine.
At 90K cylinder #5 went from 150 to 160, and at 92.5K cylider #5 was at 170, and at 95K cylider #5 was at 180, so how much credit do we give auto-rx and how much credit do we give Pennzoil Platinum.
When I look at these numbers I can say that auto-rx increased this engines compression in increments of 10. Cylinder #5 had the biggest increase with Pennzoil Platinum and auto-rx in the engine, it went up by 40 psi, so I give Pennzoil Platinum credit for 30 psi and auto-rx 10 psi. Why am I giving auto-rx only 10 psi, because after the Pennzoil Platinum was out of the engine it only saw a 10 psi increase with conventional oil and auto-rx, or just conventional oil alone for the so called rinse.
When I step out of the box, and really look hard at these numbers I come up with some conclusions, Pennzoil Platinum by itself would easily bring this engines compression numbers back up. I also see here that when you add auto-rx with Pennzoil Platinum you have PP doing 80% of the cleaning and auto-rx doing 20% of the cleaning. You cannot get away from the fact that PP did some cleaning, some members keep throwing this test out that auto-rx works, but this test proves that auto-rx works a little bit, and it proves that Pennzoil Platinum really works. If PP did not do any cleaning then cylinder #5 with PP and auto-rx should only have gone up by 10 psi.
This test also proves that Pennzoil Platinum is a cheaper and faster alternative than using auto-rx in cleaning up Ring Packs.
WHOA!!!!!!!
V8man - you've formatted this quote and your comments on it INCORRECTLY and have caused a lot of confusion!!!!!
The top half of this post is dnewtons, the bottom half interpreting the results is V8mans.
And I think that interpretation is flawed.
Compression after 2k of PP was 110psi and 120psi. If in the next 1k you feel that PP was responsible for 30psi increase, then in the 2k when PP was on its own, it had already resulted in 60psi increase which means the compression before PP was 50psi / 60psi.
Dnewton stated that he noticed fuel economy improvements and I think power improvements going from 110psi / 120psi to full / almost full compression.
So he would have noticed the same during that 2k with PP only.
You interpreted his data the way you wanted to believe it.
On top of that the way you quoted him and added your comments has confused everyone!
TWO SERIOUS MISTAKES! [/quote]
I left out the part in his post where he was giving auto-rx credit. In his opinion auto-rx deserves all of the credit in increasing his compression, I am just showing that Pennzoil Platinum really deserves the credit. I stated earlier in this thread that Pennzoil Platinum can increase compression and I was called out by Trajan and sprintman made a comment, so I responded. dnewton3's 2 threads have been around for about 6 years and Trajan seems to like this test and sprintman is talking about increasing compression. I think this Pennzoil Platinum goes with the title in this thread, Is it time to just say no? As far as using auto-rx in cleaning up ring packs or increasing compression, then we can say no for auto-rx and YES for Pennzoil Platinum.
Unlike most here who just read a thread once, when I look at a thread I will look over it many times and then draw my conclusions. There is no proof that auto-rx increases fuel economy, no oil additive can do that.
Frank D
If a person wants to spend time digging they'll see how people have changed and evolved. I'm using TCW3 along with MMO now. I also like Kreen something I wouldn't have considered a few short years ago.
As far as the Mobil 1 goes, I had 70 qts. so I'm using it up slowly.
Yes people do change.
Mystic has turned into skyship!
We have a few people who changed names and IP addresses too. Tough to prove though.
Yes there was a brief time when I was an A-Rx fan boy, most people here who know me knew that.
Say it ain't so.
Nah, Mystic is one of the good guys here.
So what happened? Why are you no longer an ARX fan boy?
I also heard you once championed thin oil.
Seems to me there are some folks who rely on point observations and what others say, while there are others who rely on establishing the correct criteria and understanding the mechanisms at play.
That's why I laugh at the Auto RX owner going along with a visual experiment.
So many people not looking at this scientifically, even people selling products!
Mystic, I still haven't heard back from you on these questions:
What's the secret ingredient in PP Mystic?
Pennzoil say Ultra cleans more so why wouldn't you recommend that instead?
I also heard that Quaker State Ultimate Durability is very similar to PP.
The PQIA testing listed the additives in ppm in full syn. Which one(s) compared to the competition suggest it cleans more than other syns or is there something else about its chemistry?
Lastly, are you saying we don't need to add MMO to the PP even though the MMO is cheap? I don't know what's in MMO and the oil and car manufacturers say don't add anything, so to me it doesn't matter how cheap an additive is, I'm not going to try it unless I know a lot more about it and how it interacts with the precisely balanced additive packages in all oils.
I see I'm in your crosshairs today. Well lets see. A-Rx briefly stopped a leak which came back with a vengeance, paid posters, and lets just say the owner showed his true colors and leave it at that. I'd rather not beat a dead horse.
As far as oil goes I believe oil should be matched to climate and how an engine is used. I'm no longer a fan of one size fits all. I'm also in pretty good company, but like everything else on this board opinions vary. I'm going to give Mobil 1 0W20 a try in my Jeep this summer. I'll let you know how it goes, its one of the thicker 0W20 oils, and Tig1 swears by it.
BTW I heard things about too.
I am just glad that Trav caught all of this. Shows everybody who is responsible and can be believed and trusted.
Eventually the moderators will lock up this post.
I tried the afe this winter on tigs suggestion as well. I had pp in before the afe. I noticed no additional noise and cold starts were pretty easy at -35 in the mornings. I liked it for winter for sure.
Summer on the other hand is a different story. The truck will rarely even get started and only to tow the trailer for camping. So 10w30 that I have in my stash will get the nod,likely RP since I've got quite a bit to use up.
Start a thread on your experiences with it in service. I'd be interested in your observations.
Not at all. I'm genuinely interested in your experience with ARX.
I think it would be interesting to understand the mechanism of the subsequent leak. It is not necessarily the case that ARX caused the leak. It may be that it cleaned up too much and exposed a leak. Maybe sometimes it makes sense to clean and sometimes it doesn't. Having more details helps us understand that.
My own interest is that I restored compression, performance and mpg significantly with Techron and Gumout. Then I went with the Walmart service and got some more cleaning of what I am assuming was carbon around the piston rings. The reason I tried the Walmart service was I had a scraping noise during acceleration so felt there was more cleaning to do. Since it worked, I'm wondering whether there is more cleaning now possible from the oil side. I don't want to use additives and am hopeful that continued use of full synthetic with annual Techron and a realization that I need long trips will keep things clean. I'm waiting to see whether the car improves further after the next oil change.
Re oil and climate, I'm interested in that too. I have seen some charts from Mercedes for the US market where 30 weight is ok above 100f and beyond while some others suggest to use 40 weight in those instances. In the absence of clarification, I'm sticking with 40 weight for my Mercedes.
But for Fords, I calculated that there have been 7 trillion miles on 20 weight oil and some of they must have been above 100f. So I think they've proven the climate / weight issue on a number of engines. If you have a newer engine, you might be right to worry.
