Originally Posted By: V8man
ARX - why it IS the miracle fluid!
dnewton3
Loc: Indianapolis, IN
I just completed my second ARX application/rinse. I don't know that there are enough superlatives I can find to express how pleased I am with the performance of ARX.
For those who don't know my story, read the whole thing here:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1128803&fpart=1
But if you want a synopsis, I'll provide this:
1997 Taurus 3.0 Vulcan; heavily coked piston rings. Very poor compression. There were two treatments of ARX application/rinse. First was an "experiment" with Frank and Gary; second was a "traditional" treatment. The initial test was 2x the dose for 1k miles, followed by a 2k mile rinse. The second application was at 90k miles with 2.5k miles application and 2.5k miles rinse.
The final result?????
ALL CYLINDERS ARE NOW AT FULL COMPRESSION! The last lagging cylinder (#5) is now up over 180psi in yesterday's compression test, along with all the rest. The following is a recap of the compression in psi, with each reading taken at the beginning of the event.
event.....2app..rns...1app..rns.....final check
milage....87k...88k...90K...92.5k...95k
cyl 1:.....170...180...180...180.....180
cyl 2:.....170...180...180...180.....180
cyl 3:.....165...180...180...180.....180
cyl 4:.....120...180...180...180.....180
cyl 5:.....110...150...160...170.....180
cyl 6:.....180...180...180...180.....180
Lets take a look at these compression numbers with Pennzoil Platinum and auto-rx, followed by the numbers with auto-rx and conventional oil. At 85K Pennzoil Platinum 5w30 was put in this engine, at 87K compression numbers were taken and auto-rx was added in the oil.
At 88K compression numbers were taken again, cylinder #4 went from 120 to 180, so that cylinder is fine. We now have cylinder #5 going from 110 to 150, the problem is that we do not have compression numbers when this engine had 85K. This engine had a mishap at 50K when a freeze plug bursted, right near cylinders 4 and 5. What is interesting is that there were no problems from 50K onward, meaning there was no sign that there was a compression problem, the engine ran fine.
At 90K cylinder #5 went from 150 to 160, and at 92.5K cylider #5 was at 170, and at 95K cylider #5 was at 180, so how much credit do we give auto-rx and how much credit do we give Pennzoil Platinum.
When I look at these numbers I can say that auto-rx increased this engines compression in increments of 10. Cylinder #5 had the biggest increase with Pennzoil Platinum and auto-rx in the engine, it went up by 40 psi, so I give Pennzoil Platinum credit for 30 psi and auto-rx 10 psi. Why am I giving auto-rx only 10 psi, because after the Pennzoil Platinum was out of the engine it only saw a 10 psi increase with conventional oil and auto-rx, or just conventional oil alone for the so called rinse.
When I step out of the box, and really look hard at these numbers I come up with some conclusions, Pennzoil Platinum by itself would easily bring this engines compression numbers back up. I also see here that when you add auto-rx with Pennzoil Platinum you have PP doing 80% of the cleaning and auto-rx doing 20% of the cleaning. You cannot get away from the fact that PP did some cleaning, some members keep throwing this test out that auto-rx works, but this test proves that auto-rx works a little bit, and it proves that Pennzoil Platinum really works. If PP did not do any cleaning then cylinder #5 with PP and auto-rx should only have gone up by 10 psi.
This test also proves that Pennzoil Platinum is a cheaper and faster alternative than using auto-rx in cleaning up Ring Packs.
This is *exactly* how c3po copys and pastes.
The ARX product flat works. Period. While it cannot reconstruct worn metal, it sure can do nearly anything related to byproduct contamination.
The only thing I regret is that I didn't take the pistons out for pictures of the coking, and then reinstall them and run the ARX. On the bright side, I didn't have to, because the ARX did all the work for me!!! And that's the whole point, isn't it? Why tear down an engine to repair the cumulative effects of combustion byproducts when ARX can do it for you!
Frank, your product is beyond any competition in the market, and it deserves all the praise it garners.
