Is it hard to find a good filter with open louvers?
If it has the cream colored potting material like shown in the Whip City video, I'd say it's good to go. Gotta look down the center tube with a strong LED flashlight and look to verify.
Isn't that the older filters. My filter is the newer version with the more flat fluted end.
Yes, the "newer" FL-1A in the Whip City video had: 1) less flutes on the dome, 2) bypass (Purolator style) in the dome end, and 3) cream colored potting material. But that was a 2 year old video, so who knows today what changes have been made since then (ie, it's oil filter Whack-a-Mole).
If you look down the center tube and see cream colored potting material around the dome end of the center tube circumference then it should be good and not shed any black glue since it doesn't use the black glue. What's it look like?
I'm going to disagree on this one. I see some black glue that oozed out at the very bottom. Guess this one is a dud. This one is dated 11-13-23 That makes me sad because this one has nice louvers
Click on this thread and go through the whole thing. ⬇️
Every oil filter I've every looked at has glue inside the inner tube. Is it just motorcraft that uses a glue that doesn't hold up?
I like the Delcos and the Microgard Selects (top tier PG). Now it Delco would out a silicone ADBV they’re be perfect. I don’t hate the ecore and they’ve been having metal end caps.
I thought the AC Delco was just an overpriced Luber Finer? Do I have that wrong. e-core, nitrile ADBV. I don't have any problem with it - but its just a basic filter no?
I have run plenty of Champ XL's - which is pretty much the same with more media and a silicone ADBV.
Noting to disagree about ... it's either uses the black or cream colored glue and told you how to verify. Sounds like it doesn't have the cream colored glue, so now that it's been verified, then I'd say it's a NO-GO.
Obviously the ones with the black glue that's been shown many times to easily come off. Throw Motorcraft under the bus and find another brand would be my suggestion.
You made it sound like the newer filters don't use the black glue. That's what I disagreed on. The newer filters with less flutes on the end where you put a cap wrench indeed have the black glue like the one I have. Back to Walmart it goes. I'll just use the Mobil 1 m-301a filter I bought yesterday. That one has black glue too, but hopefully it's a different type as the Mobil 1 filter looks very similar to the fl-1a
I simply said the "newer" Motorcraft in the Whip City video didn't use the black glue and instead showed cream colored glue. Then I asked you to look at the one you had to verify what color the glue was since that video was a couple year old and who know what's changed since then without some kind of verification. I said IF it was cream colored then it's OK to use.
Go back and watch that Whip City video again, the newer Motorcraft in that video also had less flutes on the end cap, just like I already said in post 24. So that's not a good way to verify what's going on in the inside, and why I said look down the center tube to verify the glue color.
Anyway, as I've said in many threads ... I'm done with Motorcraft junk for obvious reasons.
Anyway, as I've said in many threads ... I'd done with Motorcraft junk.
No worries man, I just went by the glue color lol
Yes, by looking down the center tube as suggested, as that's the only way to verify without cutting it open. M+H must have decided to not use the robust cream colored potting glue anymore since the WCW video, as it was too much cost and went with some cheap black RTV type of material, lol.
