FRAM Engine Oil SAE 5W-30 utilizes a blend of high-quality conventional and synthetic base stocks coupled with a robust additive system to provide reliable engine protection across a broad range of operating conditions. Specifically formulated for use in modern gas-direct engines (GDI) and turbo gas-direct engines (TGDI) as well as older carbureted or normally fuel injected gasoline engine designs. FRAM Engine Oil SAE 5W-30 contains additive technology designed to prevent low-speed pre-ignition (LSPI) while also providing increased wear protection, oxidation and shear stability over previous oil categories. FRAM Engine Oil SAE 5W-30 meets the requirements for API SP, SN Plus, SN, SM and ILSAC GF-6A, GF-5 and earlier API and ILSAC Service Categories.
Product Features:
- Low-Speed Pre-Ignition Control
- Chain Wear Protection
- Piston Cleanliness
- Turbo-Compatibility
- ALWAYS REFER TO YOUR VEHICLES OPERATING MANUAL TO SELECT THE CORRECT GRADE
Safe to say it’s a syn-blend
