Originally Posted By: unDummy
I prefer the highest HTHS value in an oil
What is Castrol Edge 10w-30's HT/HS value?
Anyway, since this oil meets ACEA A1, this means its HT/HS must be below 3.5. On the other hand, GC meets ACEA A3, which means its HT/HS is 3.5 or higher (3.6 according to some earlier specs). So, if you prefer an oil with the highest HT/HS, then why are you running Edge 10w-30 instead of GC?
Or were you just referring to 10w-30 grade in general, not specifically Castrol Edge?
