Originally Posted by 92saturnsl2
If you don't get an alignment, you run the risk of premature tire wear and possibly replacing tires a year down the road instead of several.
If you do get an alignment, you run the risk of the alignment already being fine and throwing $70 down the toilet-- or some idiot messing the alignment up. I'm about 50/50 for good alignments at chain stores (I avoid them like the plague, but basically only places near me that do alignments). Half the time the car is great for the whole set of tires, the other half the time the car comes back with the steering wheel crooked, or a pull to one side or the other. I've not had any luck getting a shop to re-do an alignment, they always come back and say it's good-- so instead I take it somewhere else, spend another $70 and have them fix the first shop's mistake. I just chalk it up to the cost of getting an alignment.
Since this is a new-to-you vehicle, do a visual check on all your suspension components. Tie rod ends should have boots intact and no free-play (can be checked by rocking steering wheel back and forth and listening for a click/clunk.) Ball joints should have good boots and no leaking. Struts should be dry and leak free. Sway bar end links (not really related to alignment, but nice to check while you're down there) should have good boots, no leaks and no noticeable slop when you wiggle them. Taking a car in for an alignment that has worn or bad suspension components is a super fast way to flush hard earned money down the toilet. Some shops will advise you to replace worn parts, others will not notice and perform the alignment anyway.
Maybe try a shop that advertises a free alignment check? Though I suspect this is mostly a scheme to get customers in the door and sell them something.
Whenever I see complimentary anything, there is always a catch, especially at a tire or a car dealership. haha
I live in a town of almost 200,000 so I am thinking there would be better alternatives to the standard chain store alignment places, because you are right, they often screw it up or make it worse.
That is a great check list for any car owner. Thanks for posting that 92saturn!
