Long ago I tried in my motorcycle tires.
They were horrivle!
I couldn't stand it any more, so a few weeks later removed them.
They were horrivle!
I'm trying to understand the logic behind this. A T-Wrench spinning in zero g inside the ISS. Why is it constantly changing?I wish one of our physicist here would explain why the beads find the opposite side of the imbalance. My non-physicist brain thinks the beads would find the same side as the imbalance and make it worse.
For the same reasons balance beads find the opposite of the imbalance, nobody seems to knowI'm trying to understand the logic behind this. A T-Wrench spinning in zero g inside the ISS. Why is it constantly changing?
Could you go a bit deeper?Newton's Third Law?
The object is precessing, with zero total external torque. It's generally true that the rate of precession is high for small moment of inertia I, and small for high I. About an axis through the shaft, I is large. About an axis parallel to the handle, I is small.
i) While it is rotating with its shaft nearly parallel to the angular momentum L , its moment of inertia is large, so it precesses slowly. Hence this rotation state seems approximately stable (but in fact is slowly varying).
ii) Once the precession takes the long axis (the handle) nearly parallel to the angular momentum L, its moment of inertia about this axis is small, so it precesses rapidly. In fact the precession is so rapid that we hardly notice it: it seems to 'flip' rather quickly to the
iii) next state with its short axis (high I) nearly antiparallel to the angular momentum L, it precesses slowly so that this seems 'stable'.
My next door neighbor taught physics and did research at the local university for 30 years. I asked him how balance beads work, to which he promptly explained it has to do with the relationship between the center of mass and the center of rotation. The beads will move to reduce the distance between the center of mass and the center of rotation. He offered to model it for me mathematically. I said that I would take his word for it.I wish one of our physicist here would explain why the beads find the opposite side of the imbalance.
Probably a great application for these, ginormous trucks.I just had to use some yesterday on a set of LT tires. It was for an f550 stake body truck. When I went to mount them on our balancer, the hub adapter for the trucks hub size didn’t work, it was improperly machined, so it wouldn’t slide over the shaft of the balance machine. Tried filing it but wasn’t getting anywhere so i broke a bead down of each and installed 3oz if equals beads in each, along with the proper stem cores etc.
Took it for a ride and it seemed fine, although with a full framed heavy duty vehicle idk if I would’ve felt a vibration anyway.
Our big truck guys use the same pack of balance beads in 22.5” wheel/tires. Unless they’re using a couple packs per wheel, I can’t see that being enough.Probably a great application for these, ginormous trucks.
