Could be ... but that's only around 10 times more shear ... not 2,000 times more like you mentioned in post #41. Plus, if you bring the engine RPM down to 2,000 to 3,000 like in normal street driving it cuts the shear rate down by 2 to 3 times. Plus, oil temps on the street running below 150C helps keep the viscosity under shear conditions higher than what the HTHS and HTFS would be at the defined 150C. I think the HTFS window on a normally driven street car is a very small and rare window to see in real life driving conditions, unless someone was in a high speed police chase going 120+ MPH for an hour, lol.
High RPM use is still going to find a low viscosity oil, even with a stout base oil, too thin in the HTFS department like you've mentioned above, and why in driving conditions like track use that gives high oil temps and high engine RPM the engine will definitely require a much thicker oil grade (as makers of high performance cars for track use recommend) to maintain an adequate HTFS viscosity. Obviously the valve train and other parts that run in boundary and mixed lubrication rely heavily on AF/AW additives and much less on MOFT. Of course any MOFT helps, even if it is less than a micron in those lubrication regimes.
