Originally Posted By: 440Magnum
Originally Posted By: bmwpowere36m3
I don't see him specifically asking for a 1/4" torque wrench... most 3/8" should be able to do 29 ft-lbs (as long full scale is .
He specifically asked for an inch-lb wrench that goes into the 300's range, so not he didn't ask for 1/4" drive. But he did ask for a tool that pretty much doesn't exist. ;-)
That's why everyone's been saying just get a torque wrench (probably 3/8") that has 29-30 ft-lb in its accurate range. You wouldn't want to use a torque wrench that goes to 300 ft-lb and assume that it's very accurate at 1/10th its maximum, but a 120-ft-lb wrench should do fine at 30 ft-lb.
His post is edited, so maybe the wording has changed...
Either way, there are in-lb torque wrenches that go that high and higher... we use them every day to build helicopters (mostly SO stuff). You can get Nm, dual scale, whatever... the markings don't really matter as you can convert between them and use "any" wrench practically (within its useful range).
