Originally Posted By: A_Harman
Originally Posted By: Ducked
Originally Posted By: raaizin
I really only use it to torque down wheels or for a brake job where I need to torque caliper brackets. An inexpensive one would be ok as long as it is accurate
For that usage checking it with a bucket of water and a bit of rope should be good enough, or just don't use one at all.
If replacing perhaps consider a beam deflection type. Not much to go wrong on them
Beam torque wrenches are such a pain to use. You have to have a good view of the scale to monitor what torque you are applying. Many places I use a torque wrench, it would be difficult to look at the scale.
True, but doesn't seem to apply to the OP's very limited usage, where space doesn't seem to be likely to be restricted, though for that usage (lug nuts again, oi vay!) he probably doesn't really need one at all.
A lot of people seem to make a bit of a fetish out of torque wrench settings. I'd only consider one essential for a very few jobs where space isn't usually restricted, like with an engine rebuild.
With a bit of fiddling about you might be able to rig up an audio contact switch alarm to tell you when you'd reached a particular pointer deflection, though I've never tried.
