I redneck fixed my quickjack down solenoid
ME
In the continuing saga of my QuickJack (tm), which needs as much maintenance and repairs as the cars that ride it up and down, I had to fix my "down" solenoid.
Background: QJ 5000 is four years old. I started developing lowering issues on one of the frames. Maine has a 4 year implied warranty on durable goods so I wrote QJ and they sent me two new frames. Sweet!
But I had been using a c-clamp to hold the "down" button on my pendant and in an amazing twist of fate I coincidentally burned out the factory solenoid by leaving it on too long. Zero ohms across the terminals. No click. Dead. The red LED for power still lit, though.
Got my new frames, and, per the directions, put a car on them and raised it. Wouldn't come down. :oops: Desperate to drive to work, I unthreaded the hydraulic fittings just enough to leak fluid and get the thing down. Not recommended-- if one pops a side that side will come crashing down. And, of course, I had to balance each side so they came down at the same pace. A nail-biter.
Now for the hard part-- finding an appropriate solenoid. It's not listed on Bendpak's parts website. The "post" sticking out of the power unit that holds the pintle barely excludes a 1/2" open end wrench, but coils are sold in English sizes.
And the answer is... the Hydraforce 6306012!
It's a 12VDC solenoid unlike the 115VAC one shipped with my unit. Perfect fit. May be the very one used on the 12 volt power units. And of course it has enough magnetic energy to bleed the fluid down.
Wired it up with an old "wall wart" and it works mint. Just have to remember to cut power when done so I don't burn out another solenoid.
I'm confident I can hack the OE wiring to make it work "normally" but for now am just happy to be lifting stuff... got a backlog of repairs, and bad weather on the way!
If you overheat the coils to the point it burns out it will swell the stem some times and a new could won’t fit on. Often the spool sticks when this happens. If you manage to get it back together it might quit again shortly.
The coil should not have burned out no mater how long you left it on. They will burn out if the spool is not moving all the way Into the coil.
Well maybe it was just a coincidence, but I blame myself for that c-clamp on the controls and the dead coil.
I did not leave the thing outdoors. Sadly it did sit on my garage floor in salty water "winter car runoff." Its replacement is getting its hinges lubed more regularly and is sitting on 1/4" plywood to stay dryer. Post-mortem on the old one shows the hydraulics working fine but at least one hinge not voluntarily folding.
sorry for the late reply. I did the same exact thing with the c-clamp and got the same exact result. Burned out coil. Just ordered a Hydraforce 6316115 which appears to be 1/2" and 115vac.
