The WiX site has specs. I'd consider a filter head that will accept a 3/4x16 filter. Theres many that can be used.
Heres a couple.
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Dodge/Jeep (82-11), Various GM, Saturn (85-07), Lexus (90-10), Saab (67-09), Suzuki (86-02), Toyota (88-11), Ford (03-11), Mazda, Mercury (05-11), Yugo (86-89), VW (09-11) Various Lawn&Garden, Farm, HD Equipment
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Lincoln/Mercury (81-09), Chrysler/Jeep/Mitsubishi (02-09), Various Mazda (94-11), Various Industrial Equipment
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Thread Size: 3/4-16
Beta Ratio: 2/20=14/31
Gasket Diameters
Part Number: 51085
UPC Number: 765809510852
Principal Application: Chrysler/Dodge/Jeep Vehicles (91-08), Mitsubishi Eclipse (95-99); Caterpillar 3 Series Excavators, 9 Series Loaders, Kubota
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.836
Outer Diameter Top: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=15/28
Burst Pressure-PSI: 340
Gasket Diameters
Attached 2.834 2.462 0.200
