I've been happy with Penetro 90 and WD40's new Specialist Penetrant which is vastly superior compared to regular WD40 as a penetrant.
Penetro 90 is almost the perfect multi-use spray lubricant, it's loaded with EP and AW but it's not a dry lube or gel lube, nor should it be used where heavy water spray is encountered.
