quote:
Originally posted by 1sttruck:
1. The Ford Explorer, most popular SUV in the US, runs fine on 5w30. One finds engine damage when trying to use 5w20. What is the problem ?
a. 5w20 doesn't offer as much protection as 5w30.
b. The Ford Explorer has a design problem.
c. Proper flow and volume requirements aren't met, leading to oil starvation and engine damage.
2. Someone club racing an Audi has cam wear problems when using Mobil 1 5w30, solves problem with Delvac 1, but the wear gets much worse with 5w20. What is the problem ?
b. The Audi has a design problem.
c. Audi's were designed and Val/Ver-ed with higher HTHS lubricants. People using oil that were not Val/Ver-ed discover problems when run under strenuous environments. VW/Audi send out TSB reminding service technicians of lubrication requirements of VW/Audi engines. Racers discovered the same thing on their own.
3. Ford states that for fuel economy 5w20 will be used in many vehicles, but some very popular models are still required to use 5w30. A few years later some of the previously excluded models are shipped with 5w20, but outside of the US Ford recommends using 5w30. Why does Ford recommend 5w20 in the US and 5w30 outside of the US ?
a. Ford needs to minimize possible warranty problems where there is no CAFE pressure.
b. Shipping the vehicle outside of the US creates a design problem.
c. Ford got around to Val/Vering 5w20 in engines of older design discovering they met flow and volume requirements. Since testing showed equal performance and availabilty of 5w20 in overseas locations is spotty at best, they chose not to take on the task bucking the trend outside NA given the trouble they have with the thick heads in NA.
