I'm done with this argument. I think it's over and done with. Viscosity is just one aspect of an oil. Ford tested the 5w-20 rigorously in Arizona and it held up better then the 5w-30.
Q. Were engine designs modified to run this new grade of oil?
A. Some bearing designs were optimized to take advantage of the new oil. New engines will be designed to take advantage of 5W-20.
Q. Who makes Motorcraft oils & Lubricants and is it important?
A: Conoco manufactures our main high volume bulk and packaged products and many of our lower volume packaged products come from Excelda Manufacturing who has several 2nd tier suppliers. The supplier is not as important as the specification and the performance of the final product. What is important is that Motorcraft oil is blended to FCSD's specification, which exceeds the minimum industry specifications for ILSAC GF-3 (API SL) for gasoline engines; ILSAC CH-4 (API SJ) for our Diesel Oils and even exceeds the Ford specification. It is the only oil that can truly claim it is Designed, Engineered and Recommended by Ford Motor Company, for your Ford, Lincoln, or Mercury vehicle. No other motor oil or lubricant can make this claim.
