Yes, this was not a good bridge design by current standards, but the fact of the matter is they were designed and constructed all over, and many of the type still remain in service today. Would a similar design be done today? Not likely. We've learned too much since then to keep doing things the same way.
Cetainly this bridge was exposed to a climate that was harsher than many bridges experience, but no different in temperature extremes, snow, etc... than bridges throughout the state. The major issue that plagued the driveability of the bridge over the years was the constant moisture that was availible that caused serious black ice problems in the winter. The moisture was availble by virtue of St. Anthony Falls on the Mississippi River and a nearby heating plant. The moisture probably has played a role in overall corrosion of the bridge.
The black ice issues were severe enough that an automatic deicing system was installed in 1999. Since 1999, our usual deicer of Sodium Chloride (Salt), that we use everywhere else, was replaced by Potassium Acetate on this bridge. Theoretically, Potassium Acetate is supposed to be much less corrossive, making its use attractive on the bridge.
Overall, this bridge has certainly had its issues up to the point it failed and its poor design was part of why it was inspected on a yearly basis. The inspection crews through the years look like it has had many of the same folks associated with it - did over familiarity with the bridge lead to missing something?
I'm confident that a solid answer to the reason for the failure will be found and we'll all learn from it. With the video evidence, lots of information collected over the years, and several concurrent investigations happening, hopefully that will be the conclusion.
