Hi all,
I'm maintaining my GF's 2012 Kia Forte LX 2.0L with (I think) 6 speed AT.
It was overdue for an ATF change, so I opted for a drain and fill. Local mechanic quoted $250 for the job and dealer wanted even more. Times are tough, so I opted to do it myself.
So, some background:
Should I be worried about that discrepancy? How much tolerance for fluid level do these sealed transmissions usually have? Should I let the tranny cool and try to do the PITA level check properly tomorrow?
And also: I'm thinking about going out and get the ****ed 24mm socket to torque the bolt. Would you all say it's worth it, given there are no leaks?
Thanks, folks.
- Got general info about the procedure from Forte forums.
- Despite many swearing by the Kia-branded ATF, I opted for Valvoline Maxlife based on comments there, which I think were referring to this post about a same-gen Forte hitting 360,000 miles on the Valvoline.
- Found a video about how it was done on another Kia -- a few sources confirm that most Kias have this same model AT (and things were where I expected them to be after watching the video). They also used Valvoline Maxlife and reported good results.
- I opted not to follow the process described in the video, instead going for drain-measure-fill.
- I did this using 2 measuring cups, made for cooking (they were brand new) -- one for old oil, one for new. After draining the old oil, I poured as much of it as I could into one cup, then matched the amount of old oil with new oil in cup #2. Poured new oil into fill hole, old oil into container, repeat process until drain pain is empty.
- In case you didn't watch the video, I went this route because the fill-via-level-check-hole process was nuanced. Has to be the correct temp, completely level, and doesn't just not leak if it's full -- a "small stream" pours out when it's at the correct fill level, and you're meant to refill the amount bled. Weirdly subjective measures, and I don't have a lift. I figured that the fact that "small stream" is so loosely defined means that there's at least some wiggle room designed into the AT.
- Part ways through, I realized I didn't have the right socket (24mm) and decided to proceed loosening the drain bolt with an adjustable wrench, which means I didn't torque it to spec on replacement.
- I retightened by hand, and checked for leaks after warming up the engine for 30mins at high speeds. There were none.
- I screwed up the first "fill" by going a bit too fast, underestimating just how slowly you have to drizzle the new oil in without a breather (the level check hole).
- I realized this quickly, and ended up with only a really small puddle on my garage floor. A few drops at most.
- I "compensated" by adding like maybe 50-100mL or so during the fill according to the measuring cup.
- After finishing as accurately as I thought I could, I went for a 30ish minute drive, scaling up the speed as I went to see if anything would explode. Got nervous about the few drops of difference between old and new oil and ended up draining via the level check afterward.
- More came out that expected. I repeated the drain-measure-fill process and replaced what came out after realizing that the excess heat (supposed to be 10-15min at lower speeds) affected the viscosity and probably nullified the check.
Thanks, folks.
