Accord 2.4L CVT behaves the same after the CVT fluid change as it did before the change. Warmed up to operating temp before draining. Drained, refilled, taken through each gear (3-5secs) a few times with engine running. Then open overflow to fluid drizzle seen. Close overflow, drain and overflow bolt torqued to spec. That's it. Of course, level ground for draining and level check.So you've never had a problem.....
