- Joined
- Jul 29, 2022
- Messages
- 14
I drive an older Toyota automatic. The transmissions are extremely sensitive to fluid viscosity and level. If you are off by a few fluid ounces you can definitely feel it in the shifts. The process for fluid leveling is extremely precise. You have to check the temperature of the ATF, level it on the dipstick.
Then you clean the MAF, reset idle, reset TCM memory. It's very involved and a headache. I trust no one else with the job.
Comparatively, Honda CVT/Auto fluid leveling seems very straightforward and imprecise.
It's almost like you're filling gear oil. You just let the fans come on twice and drain the overfill? What the hell? You don't even check the temperature of the CVT fluid? How is this accurate?
