Ammofirst
Not sure.Aren’t these problems engines coming out of the Alabama plant?
I'm pretty well convinced that a lot of vehicles are designed for leasing, not owning. I can think of a few brands I might lease but would never buy.Not sure why its hard for some to accept that certain cars are 100k mile appliances. You drive them for a while then get another one. I rarely keep a car past 100k.
There is no reason to have ongoing engine issues for 10+ years
That's totally fine that you "rarely keep a car past 100k", but for many that isn't financially feasible. Also, I do have expectation that my vehicles will exceed 100K with normal maintenance, as we all should. Why would we had over $20K+ to an automaker for a new car and expect anything less?Not sure why its hard for some to accept that certain cars are 100k mile appliances. You drive them for a while then get another one. I rarely keep a car past 100k.
Mines been rock solid 140k miles.I was JUST about to mention that the 1.6 Gamma had the lowest amount of warranty claims for many years. I don’t have that data anymore but it might still might have the lowest warranty claims out of Hyundai’s lineup. The 1.6 Gamma has been reworked in the last couple years so I can’t speak to its reliability.
Audi piston rings don’t “break” the 2nd gen 1.8 and 2.0 tsi can use oil but they don’t loose compression like a broken ring would. Also Audi will foot the bill to repair if you have full service history up to 100,000 miles. Doesn’t have to be main dealer history either.Every car maker has their issues.
Toyota......slugging up piston rings....Audi.....breaking piston rings in their 2.0t engines.
Hyundai is part of a crappy club...but they are not alone.
Unfortunately it isn't like Hyundai, because otherwise they'd guarantee the engine/it's defects without service records for life.Audi piston rings don’t “break” the 2nd gen 1.8 and 2.0 tsi can use oil but they don’t loose compression like a broken ring would. Also Audi will foot the bill to repair if you have full service history up to 100,000 miles. Doesn’t have to be main dealer history either.
Not anything like Hyundai.
Sorry - - - Yes they did.Audi piston rings don’t “break” the 2nd gen 1.8 and 2.0 tsi can use oil but they don’t loose compression like a broken ring would. Also Audi will foot the bill to repair if you have full service history up to 100,000 miles. Doesn’t have to be main dealer history either.
As a side note it took years for Audi to actually admit to a problem......AFTER being taken to court.Audi piston rings don’t “break” the 2nd gen 1.8 and 2.0 tsi can use oil but they don’t loose compression like a broken ring would. Also Audi will foot the bill to repair if you have full service history up to 100,000 miles. Doesn’t have to be main dealer history either.
One of the other techs at works uncle has a Hyundai Tucson. Was just over 5 years old with 35,000 miles (warranty 5 years 100,000) when it developed a transmission noise. Had it into the main dealer who removed the transfer box and it’s got worn output to input shaft splines between gearbox and transfer box. Quote for repair was £14,000. He rings Hyundai UK and complains this car is low mileage with full service history with the same main dealer. Do they care? Nope not one bit.
That’s the end of his Hyundai ownership days. He told the dealer to put it back together and sold it to webuyanycar.com
He may have broken them himself but I’m sorry they don’t. I’m a Audi master tech so know what goes wrong in there engines. It’s easy to break a piston ring and go oh look that’s broken. Not scraping the oil off the cylinders and causing the engine to burn oil, now that’s a different topic entirely.As a side note it took years for Audi to actually admit to a problem......AFTER being taken to court.
We took our A4 in 4 times over 1.5 years for this issue.
Ring problems have happened in the past.
