Originally Posted By: JAG
Mark,
Here is where you can get MSDSs for Japan:
http://www.msds.exxonmobil.com/psims/psims.aspx
Here is the PDS for M1 0W-30 AFE showing pour point:
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_0W-30.asp
Agreed that M1 5W-30 might tolerate high temperatures better in terms of deposit formation. We can't be sure based though since it's possible that 5W-30 was chosen for marketing reasons to be the only M1 viscosity grade that passes the HT0-06 spec. or maybe that spec. only allows 5W-30. I don't know if either is true because I'm not on the inside of XOM (obviously) and I've never seen details on the HT0-6 spec.
I've never heard of a M1 0W-30 European Formula sold in North America. I think the name "AFE" is fairly new but am not sure if it was just a renaming or that plus reformulation.
I know that the EP formulations changed years ago. In addition to specs. met being different, the additive package changed significantly as shown in UOAs and Product Data Sheets. The old versions had higher metallic element content in the add package which can have a significant effect on fuel economy. I also know that there are several high PAO content boutique motor oils that are not API Starburst certified. It is also true that there is no accident that there is a correlation but that does not imply a cause-effect relationship. There are several potential reasons: high cost of certifying is a big one and also those certifications not being a high enough priority of those companies' customer bases. An oil company would be unwise these days to make an oil high in PAO content for use in an oil meant to meet API SM/GF-4 and be used for factory recommended OCIs. The cost to them is higher than if Group III were used and they'd still end up with the same certifications.
What I asked for proof on is what's below in bold:
Originally Posted By: Mark888
It is no accident that the boutique oils with very high levels of PAO are not API startbust (Energy Saving Formula) certified.
M1 had to change their EP version a few years ago to get the starbust certification and lowered the amount of PAO/Ester stock to do it.
Motor oil companies are finding out that a high quality Group III oil with some modest amount of PAO/Ester stock provides adequate protection
and yields better gas mileage benefits over 100% PAO/Ester.
I checked out 3 different 0W-30 MSDS's on the website you provided:
- EXXON MOBIL CORPORATION (country USA selected) Revision Date 21JAN2005
- EXXONMOBIL ASIA PACIFIC PTE. LTD. (COMPANY NO.: 196800312N) (country USA Selected), EHS Approval Date: 23APR2002
- EXXONMOBIL YUGEN KAISHA (Japan country selected) Revision Date 05April2009
All three have different specs and I suspect that at least two of them are different oils (but I have no proof of that). It is hard to tell whether the specs are just sloppy MSDS record keeping, out of date, or if they are different oils.
Regarding the change in formula for EP, I read the M1 website very carefully a few years ago regarding their EP oils, and they flatly said EP oils were not API Starburst certified and they were not recommended for engines still under warranty. Then they changed the website to say they were all certified (except 15W-50), and that EP will not void a manufacturer warranty (assuming the appropriate viscosity is used). So I have reached the conclusion by deductive logic that they changed the formula. I have no proof, but I would willing to wager a moderate sum.
Regarding the lack of certification of 100% synthetic boutique oils, I completely reject the explanation by Amsoil that it is too costly do get the certs. Virtually all of their non-100% synthetic oils are API Starburst certified. So I don't believe it is a coincidence that not a single one of the 100% synthetic Amsoil motor oils are API Starburst certified. And I don't believe it is a coincidence that other high PAO content oils are not API Starburst certified.
Regarding M1 0W-30 European Formula oil, I definitely saw it about a year ago. It had certs similar to GC, which is very different than certs for M1 0W-30 AFE.
