HPL Green in 2023 Tundra
Spent the whole day swapping ATF and Diff Oil to HPL in my 2023 Tundra non-hybrid. Got a 5 Gal pail of Green ATF and ended up using all of it for the transfer case and flushing the transmission. Truck had 60k on it and the Green ATF shifts much better than the old stock ATF. For those looking for a transmission fluid for the Toyota 10 speed transmission this is highly recommended. I'll update after a few thousand miles but initial impression is very good. Time will tell with the Diff Life 75w-90 I put in as well but was thinner than the Redline I pumped in prior.
I’ve got some green when it comes time for my next fluid swap in my 8 speed Toyota/Austin transmission. It’s good to hear you like the results with it!
I’ve got a case of AMSOIL Signature Series blue cap waiting to go in my 24 Tundra. Today I changed the rear differential to Severe Gear 75W90.
Was there heavy a lot of metal on the drain plug magnet? My Taco was shocking how much metal was on it. Clean as a whistle now.
Lol. My beloved 15 Tacoma required 75W85 I believe. Used Severe Gear 75W90 with no issues.
We were talking about ATF - what are you talking about? Manual transmission? Transfer case? Differential?
Yeah, mostly people with Hondas. I've done three personally now of the years, shifts better IMHO. I'm also thinking 1000's of customers
I've used AMSOIL Signature Series and HPL with good results on my Honda transmission. Thankfully no issues yet using (imo) better fluid than DW-1, type...2 fluids.
