- Joined
- Oct 6, 2020
- Messages
- 2,232
Hello, everyone,
I am planning some spring maintenance on a 2011 BMW 328i X-Drive.
It currently has 128 thousand miles.
I want to change the transmission fluid and filter, along with changing the transfer case fluid.
The plan was the drop the pan, replace the filter, gasket, clean the pan, and refill with Valvoline Maxlife ATF. And then do a few more drain/fills.
And for the transfer case, just to change the fluid along with a new drain/fill plug.
But I am just worried that the millage that I'm at is too late, and I will cause more damage compared to not touching the transmission and transfer case.
I'm not having any issues with the transmission or transfer case. I'm worried about longevity.
The differentials are getting changed out with Redline 75w-90 GL-5, so that is one less fluid I need to worry about.
I will also be completing an oil change, and power steering fluid swap with CHF-11S.
I am just looking for any general advice or past experiences to aid in my decision.
Thanks again!
Thanks again!
