Mark C:
WRT your mirrors, horn and A/C, can we assume that you've checked the subject fuses? If this is a "salt belt" car, you may also need to go in and clean up all your ground connections. Is there a charge of refrigerant in the A/C system? It won't run if the refrigerant is real low or all gone.
