How much oil does a Mitsubishi 1.8L take?
oh, well I always fill the filter full of oil and I'm using an oversized filter as well. ST 2808 I have in stock. I bring the level a millimeter over full.
hey jelly,
what mitsubishi do you have? there are not that many on this board with mitsubishis
[ September 19, 2003, 02:58 PM: Message edited by: Cutehumor ]
Thanks, gentlemen.
If anybody knows anything about horns that don't work,electric mirrors that don't work, or AC that won't work, I could use some help!
Mark C:
WRT your mirrors, horn and A/C, can we assume that you've checked the subject fuses? If this is a "salt belt" car, you may also need to go in and clean up all your ground connections. Is there a charge of refrigerant in the A/C system? It won't run if the refrigerant is real low or all gone.
