Originally Posted By: OneEyeJack
"Then it's not the same car you purchased if you substantially "rebuilt" major components. On most cars out of the rust belt you could perform the same task and put a half a million miles on them. I think we are confusing "reliability" verses just how long an owner wants to keep rebuilding a car."
Sorry, it's exactly the same car. The transmission received only bearings, seals and some spacers. Oh, and a clutch kit, too. Nothing else was changed. So it's the same transmission.
The engine was in good working condition and only the oil rings wore out and the smog laws forced the rebuild.
I don't understand your claims that it's not the same car.
It's a reliable car. Everything works, the W/S wipers, everything under the dash, the switch assembly on the steering column, all the doors, windows and door locks. Nothing has failed. Can you say that about most other 30 year old cars that have been in continuous use as a daily driver? The major failure to date has been the rheostat that controls the brightness of the dash lights. Now they stay the same all the time. I hope that would not classify the car as unreliable and unacceptable to you.
Buy the way i'm changing the master cylinder this week for the first time. And some tie-rod ends and a few pieces in the suspension. Does that make it a different car, too?
And I still can't help you with broken parts.
I'm sure it's a great car, but you do make it sound like all you've done for 30 years and 400k miles is put gas in it and change out the dimmer for the instrument panel...which we all know isn't possible. Any car that isn't in the rust belt will run forever if you're willing to repair it. Look at the cars riding around in Cuba.
