Originally Posted By: sl1driver
Originally Posted By: gregk24
I do like the fact that there would be one less dry start if you didnt change the oil filter.
You can avoid dry starts after an oil change by adding oil to your filter before installing. The filter in my Equinox installs vertically so I can completely fill it. The filter in my Saturn is horizontal so I add enough oil to wet the media but I don't completely fill it to avoid oil running every where when I turn it sideways to install it.
Yes!
I don't have a Saturn but I used to have a Taurus. For that car in every brand filter, and every other car and brand can-type oil filter I've used, I've found that (after a few minutes) the first oil fill gets 100% absorbed. The second fill gets ~40-60% absorbed, allowing tilty installations with no drip problem. For Horizontal installations I just put a little bit in the second fill, maybe 10-20%, again no drip problem.
Long ago I used to pull the coil wire and crank until the oil light went out, but have found pre-filling to work better, and besides, coil wires are pretty scarce nowadays.
Maybe it amounts to nothing measurable, but it makes me feel better to see the oil light go off instantly on startup.
Yes!
