quote:
Originally posted by MGBV8:
On basis that tech info provided by Silkolene is the diester in Silkolene, will the number of layers be the same for other ester oils eg Redline Motul
http://www.silkoleneoil.com/techtip8.htm
and how does this compare to tackifiers in other oils.
Silkolene's website:
"Electrosyntec molecules behave in this way. When a layer of Electrosyntec molecules is in place, another layer will be attracted to the outer positively charged ends of the first layer of molecules and then another to the exposed negatively charged ends of the second layer and so on, This is electrostatic adhesion and it has been shown that these layers do exist, and that anything from 10 to 50 layers can build up on a metal surface."
An additive website:
http://www.ram-energy.com/energester.htm
"The highly polar ester molecules in Energester are attracted to positively charged metal surfaces thereby creating a film that requires additional energy to penetrate."
A Motul website:
"Thus, there are two types of synthetics, one a petroleum product and the other from vegetables. A synthetic will find a leak A vegetable synthetic has a property we call unctuousness or oiliness.. It is polarized and actually has a negative end chain and iron and steel have a positive end chain. What happens is that the oil is attracted to bare surfaces and is trying to spread to wherever there isn't any oil." (speaking of esters)
From an elementary chemistry text:
"A neutral atom or group of atoms becomes an ion by gaining or losing one or more electrons or protons. Since the electron and proton have equal but opposite unit charges, the charge of an ion is always expressed as a whole number of unit charges and is either positive or negative. A simple ion consists of only one charged atom; a complex ion consists of an aggregate of atoms with a net charge. If an atom or group loses electrons or gains protons, it will have a net positive charge and is called a cation ."
Summing it all up, esters - polyolester or diester - are attracted to the metal parts of the engine.
Esters - polyolester or diester - are commonly added to polyalphaolefin based synthetic motor oils to balance seal swell (solvency). Serendipitously they increase film strength and provide a polar attraction to metal surfaces. Silkolene and Redline contain esters. So does Mobil 1, which is why you find Mobil 1 "climbing the dipstick".
So do several other past and present polyalphaolefin-based synthetics and some Group III "synthetic" motor oils.
