They all say to turn them back down to their lowest setting after use. Does that mean, after the end of the day, after each bolt, or something in between like if you're not going to use it for a half hour.
Is it a split-beam?My wheel torque wrench has been sitting on its torque spec for 30 years. Still within 2# when I check it twice a year.
LOL!Is it a split-beam?
It takes somewhat a long time to have an effect, there is a spring inside that if you leave it at a setting it can loose its ability to decompress which can affect accuracy.The OM should tell you if your particular model should be set to 0 (or in some cases, to the lowest value). As others said, I do this when I am finished with it (e.g., after the last wheel is on).
That said, I don't think leaving it set to torque value will have a huge effect on the performance, but why risk it?
I have a cheap torque wrench from EPauto, it works very well and i only paid 40 bucks for it. I got it on amazonI needed a cheap torque wrench from harbor freight to leave at my parents. I went through 3 of the 3/8 from Taiwan. What I noticed is that some of them out of the box were left on 10-20ft lb. When I used my digital torque wrench to check each one, the ones left on the setting were almost exactly 10ft/lb higher than whatever was set. So yeah, it does seem to affect the spring. Only 1/3 worked correctly, but this one was spot on very accurate.
