So I think I'm ready for an upgrade from the Harbor Freight(pittsburgh) torque wrenches. Recently did a vvti gear job and ended up snapping a cam bolt! Went and replaced the torque wrench and all was well after I walked the snapped bolt out. I think after that I will not be using Pittsburgh for any kind of engine work.
I do intend to rebuild an engine from the ground up at some point, so something that can handle more than just camshafts would be ideal.
I'm torn between beam, split beam, click and digital wrenches
I'd like to know which specific brand is reliable, because I've heard different things across the board.
I'm looking for precision between the 5 ft-lbs to 100 ft lbs range, ideally one tool to get the job done and done accurately.
My budget is looking like $150 more or less.
Thanks guys.
Thanks guys.
