I bought a 3/8" 10-100 ft-lb torque wrench a while back. My intentions with it was to torque up everything from caliper bolts, to transmission pan bolts. It seems like this the range on this torque wrench is either too low or too high.
Would I be better off returning this and getting a dial type torque wrench, like this: http://www.sears.com/shc/s/p_10153_12605_00944978000P?keyword=torque+wrench
The range is 0-75 ft-lbs on it so I should be able to do the smaller stuff with it. Such as the trans bolts that require 97 in-lbs (about 8ft-lbs)
