Hmmm. Multiple posters seem to interpret that I claimed a coolant concentration change would result in a 20C temp reduction - not sure why that interpretation is dominant, that's not at all what I said. I do completely understand that "target" isn't reality - my statements were all conditional because we have not seen any data on whether the cooling system is achieving target or how far from target it is. (e.g. I wrote *IF* coolant is at target temp, THEN turning on the heater won't help).
Sorry, I didn't intent to assume anything, I just tried to avoid any misunderstanding to any reader where possible.
- IF coolant temp cannot reach target THEN I would absolutely expect that lowering concentration AND running the heater will help (permitting the heat exchanger to transfer more heat from the oil by increasing the temperature gradient between oil and coolant)
Agreed. However it's safe to bet at 122°C oil temp it's impossible the coolant is even close to 85°C. Something 110°C is much more likely. Due to the oil/coolant heat exchanger the delta can't get that huge. That's why it does exist. Obeserving coolant temps via OBD gear would be my next suggestion to the OP.
- IF coolant temp is reaching target THEN I don't know that changing concentration or running the heater will do anything
Craig, I understand you're saying that to help understanding, but since this is extremely unlikely or even impossible under the OP's hillclimb scenario, it could also lead to some misleading. However I'm pretty sure 25/75 mix will help to come
little closer to the 85°C target. See Dave's post.
- IF the OP has any way of lowering the temperature target in advance of the run (like I can on my N55) THEN that would also help significantly. (cabin heat may play a role here, it could bring the coolant temp below target, even if the target can't be lowered prior to the run)
Agree, but it isn't that easy as it's on a BMW. Some aftermarket tunes might have this implemented, but they also add power and more power means more heat. Hard to not use the addional power on a hill climb.
- IF neither of these avenues can lower temperatures AND the OP cannot modify in any way THEN a higher HTHS oil will likely help with engine protection but may make the temperature problem worse - worth a try but I'd recommend baby steps, not going straight to 15W40 from 0W20 (random example, I'm not saying that someone here actually recommended that)
Even IF the 25/75 coolant mix
does somewhat lower oil and coolant temps (which is to be expected even if we don't know how big the drop will be) I'd definitely also go one step thicker > 5W-30 VW 504 00. The OP ordered M1 ESP 5W-30 anyway. There's no argument against this dual approach. I agree to just make a smaller step, and there seems to exist some consensus on that. Another one is, that 0W-20 isn't ideal in this case.
- IF temperatures can be brought more under control THEN switching oils may not be necessary at all - the runs are 45-100 seconds, not 45-100 laps. Changing it more often and doing UOAs might be a good idea.
Same as above, I understand you're saying that to help understanding, but since this is extremely unlikely or even impossible under the OP's hillclimb scenario, it could also lead to some misleading.
- Because the GTI has a mechanical water pump, at the conclusion of runs the OP may wish to elevate from idle to something like 1200 or 1500 to pump coolant through the system faster. I assume that with every temperature well above target, thermostats will be wide open and electric fans will be running on max trying to shed as much heat as possible. Even better would be coasting downhill in a lower gear at 2000-2500 moving through fresh cooling air with no fuel being burned at all. Of course, then the system will set the highest target temp again for "efficiency" and "pollution control" so it'll probably only get down to 110C before everything closes off again - then add cabin heater on top of that I guess. Finding a legal way to tell the ECU to set the lowest target (e.g. 85C) at all times would be immensely helpful. The oil might only rise to 110C during a run if it started at 85C - problem solved.
Raise rev to 1500 rpm seems a good idea. Another one would be to open the hood and/or spray some water onto the radiator. I thought about coasting downhill, but rules may not allow to leave finish immediately. You're probably right with the target going back to "efficiency mode" (107°C). That sad, but coolant temp will be somewhat elevated anyway.
At any rate, I'm not looking to pick any fights so I'll be reading with interest to see where the OP goes from here, what additional data is provided and I learned a little about VW engine management along the way...
It didn't appear that way, don't worry.
