- Joined
- Mar 19, 2022
- Messages
- 768
Chrysler Pentastar in my work van. I connected a scan tool for an unrelated radiator fan issue. Looking at live data I discovered 83psi oil pressure on a 45F cold start. The 2 speed oil pump always seems to be in high volume mode below 1100 RPM.
Normal operation oil temp is 195F and idle oil pressure (high volume mode) is 38 PSI. Running down the highway around 2000 RPM (low volume mode) is 40+ PSI.
So, I'm going to go back to a 5w-30 and see what pressures are. I've got 2500 miles on this OC so far, so I'll wait until hotter weather and see what temps and if anything is different. I'd expect temps to not fluctuate that much with the infamous water to oil cooler.
