5w30 ESP will do just fine
Ok, you want less parasitic drag but stout oil.250 runs, not 250 events. A run is anywhere from 40 seconds - 2 minutes.
122c is ok and normal for motor oil and an engine. He might see timing pull back around 130-135c and complete limp mode above 140c. For a good oil that is not an issue. I pushed my BMW to 149c when limp mode kicks in.While an oil temp of 235°F = 113°C is pretty normal for this kind of engine, 252°F = 122°C certainly isn't.
That's pretty close to where the ECU will start to cut some power and that's for a reason (it's somewhere
in the 120s°C I'm pretty sure). Oil temps that high along with high revs will likely affect the engine's life
expectancy in some way. So yes, that's a reason I'd worry about. As a consequence two things are required:
- bring down the temperatures >> alter coolant mix ratio >> use 35 % anti-freeze & 65 % distilled water
- change both engine and gear oil >> use a more stout engine oil (VW 504 00 5W-30 or VW 511 00 5W-40)
Use either VW G13 or G12evo and distilled water only:
35 % anti-freeze & 65 % distilled water >> -20°C frost protection
40 % anti-freeze & 60 % distilled water >> -25°C frost protection
If required change coolant before and after winter. In any case change coolant frequently (3 - 5 years)
if you run a reduced anti-freeze content since anti-freeze also provides corrosion protection and less
anti-freeze won't provide sufficient corrosion protection that long as 50/50 mix would.
Btw., is your GTI stock? Is it DSG or manual? The very first and preferably very early gear oil change is
the most important one, no matter if you have a manual or a DSG transmission.
While more frequent oil changes are a good thing, they won't help much in this case.
I think oil oxidation and wear metals are not the issue here, it's MOFT and temperature.
This isn't a race car, it isn't even a track day car. VW never made any recommendations for this duty.
This lap timer is a gimmick without any meaning.
Yes, both Porsche C30 5W-30 (equivalent to VW 504 00) and Porsche C40 5W-40 (VW 511 00) are
excellent choices and by far better suited for this purpose. I'd recommend two oils in particular:
- Mobil1 ESP 5W-30 (VW 504 00, MB 229.51, 229.52, Porsche C30)
- Ravenol RUP 5W-40 (VW 511 00, BMW LL-04, MB 229.51, Porsche A40, not C40)
Please don't mix different grades, there's no need to. Choose between either 5W-30 or 5W-40 or
use one in the winter and one in the summer season. I'd suggest to start with the reduced anti-
freeze and 5W-30 VW 504 00/Porsche C30 oil and see what oil temps you get with this. They'll be
lower, that's quite certain. If it isn't sufficient you could try 5W-40 VW 511 00/Porsche A40/C40
next. Mentioned approvals are very demanding resulting in stout oils. Of course there are other
oils out there meeting the same approvals, however that's what I would run in your case. Mobil1
and Ravenol's racing line are both very high quality and come along with reputable approvals.
I agree on very most posts made in this discussion. It's more important to protect the engine and
to avoid engine defects over warranty concerns since racing it already voids the warranty. I'm sorry
to say that, but if you really neet to retain your warranty you'd need to stop racing.
It will. But for this purpose, IMO track specific oils will do better job.5w30 ESP will do just fine
Does the 911 have a GPF in Europe? If so than a C30 should be up to track duty.It will. But for this purpose, IMO track specific oils will do better job.
Or C40. I mean for vehicles that see track once a month, sure. But, here we are talking competition vehicle. Is competing Porsche going to have GPF in the first place? It is huge restriction.Does the 911 have a GPF in Europe? If so than a C30 should be up to track duty.
I think you could throw a stock Carrera around Hockenheim pretty good. GPF or not.Or C40. I mean for vehicles that see track once a month, sure. But, here we are talking competition vehicle. Is competing Porsche going to have GPF in the first place? It is huge restriction.
+1His 2019 is specced for 0W-20. Going one step thicker ALONG with improved cooling (35/65 mix) should give a noticeable improvement.
IF he thinks he'd need an even more stout oil than M1 ESP 5W-30, then I'd go Ravenol REP 5W-30. This is also C3 and comes with MB229.51 and BMW LL-04 approvals. Exceptional pourpoint, flashpoint, Noack (6 %) and HTHS of 3,7.
IF he should see any need for a really stout 5W-40 I'd consider Ravenol RCS. I use it in my old 930 Turbo.
More ZDDP. Some track oils are at 1300ppm for a reason (Mobil1 15W50). A40 like M1 0W40 are around 1100ppm.I think you could throw a stock Carrera around Hockenheim pretty good. GPF or not.
I would have no hesitation using a 504/507/C30 in place of a 508/509 oil for track conditions. What is really to be gained by going to a 502/505/A40 oil? more Z&P?
Track oils such as Motul 300V are perfectly ok for 3-5k runs based what we have seen here. In EA888 that oil won’t have any issues to reach appropriate temperature.Yes but track oils aren't really meant to be used long term and use additives that really need a good amount of heat to become fully active. When I think of track oils I think of someone putting them in for a HPDE weekend, putting a few hours total on track, and then draining after again, unless of course the car is a dedicated track car or sees little street driving. The guys that are using them in their daily drivers because they go to the drag strip twice a month are really not using them correctly.
502 stuff is not a track oil of course and is probably better slightly suited to long track sessions than 504, but for 20 minute sessions or in the OP's case, a few minutes at a time is no problem at all.
Not so under some circumstances.122c is ok and normal for motor oil and an engine.
I understand that and I absolutely agree.Not so under some circumstances.
First, it's good to know that racers are improving HP by reducing viscosity. However, those who are successfully racing a 0W-20 oil ALWAYS manage oil temperatures very well. Often by using dry sump systems and a very large oil cooler system that is thermostatically managed. A high RPM racing engine will see 100c oil temps using 0W-20.
Street cars that tend to experience ever climbing oil temperatures during competition always go with robust oils to prevent excessively low viscosity. The thought that today's engines are somehow different, and therefore have different needs than engines of the past is absolutely incorrect. Not only is bearing clearance often exactly the same, but so are the loads the bearings are subject to. Some engines use lighter pistons than in the past, but remember, RPM is higher, result=same bearing loads.
Remember that inertial loads on the rod bearings are RPM related, and peak load occurs around TDC, on the exhaust stroke.
Well, his engine is already recommended for 0W20, which I think for this particular engine is too thin, but whatever.Do people really think that running lower viscosity is ever advisable for the hobby racer?
This is the stuff for serious racing...I would think mechanical reliability always would favor higher viscosity within reason of what the vehicle was designed to run on.
